Ventless fireplace
John Rubbo
32
Hello,
Just wanted some clarification here. I recently purchased vent free gas logs and when my flue is closed the gas smell is terrible. To the point of bad headache. When I Open the flue and its fine. Zero smell. Am I essentially making my ventless logs VENTED by opening the flue?? Really wish I would had done more research prior to buying these things. Do I bring these back and get vented logs? So confused
If you are burning them with the damper opened, they are no longer ventless.
Unfortunately, vented, vent-free or burning wood in an open fireplace isn't very efficient
& is a waste of your energy dollars...
At this point I don't even care about heat efficiency. My first concern is safety. Anyone else have issues with the smell from ventless logs?
Reactions: nick0812
Almost EVERYBODY who burns household vented appliance will smell something. The open flames allow for the burning of anything that can float in the air to burn. That includes (& is not limited to) dog & cat dander & hairs, dust, & aerosol sprays. The other downside is the amount of moisture you're gonna get in your home. For every 100K BTU of gas burnt you'll release a gallon of water vapor into the air. If you've got an old leaky 1850s farm house, that extra moisture might be welcome in the dry winter months. In a newer, dusk's a$$ tight home, any unfinished wood will absorb that moisture & swell.
I would never burn ventless in a fireplace (especially one previously used to burn wood) in a primary living area. Soot, headaches, smells are common. If you don't care about heat or efficiency just leave the damper open.
I think there's something in the log sets too. I've yet to walk into a place with a VF with a log set that doesn't have a smell, and it's very distinct. However, we have a little VF wall heater and it doesn't have that smell. Kind of makes you wonder.
And I agree, I wouldn't run a VF in a tight, or even semi tight house. We heated our Old House with a VF stove one year exclusively and it was fine, but that place was a sieve. I've been in places with them that are tighter and I can't breath well and get a headache.
