    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. gsspike Member
    I have a VC UVS27M N gas wood stove and we are moving to an area that only has Propane.
    We really like this stove and want to take it with us. VC's customer service is the worst I have dealt with.
    They made a propane version of the same stove. What do I have to do to convert this stove?
    http://dl.owneriq.net/a/a1576d25-d373-4956-bd2f-42b6fd151901.pdf
    #1
    Helpful Sponsor Ads!
  2. DAKSY Super Moderator
    From the manual:
    This appliance is only for use with the type of gas
    indicated on the Rating Plate. This appliance is not
    convertible for use with other gasses.
    Leave it in place & buy something else.
  3. gsspike Member
    But if they offer the same model in propane why can't I order all the parts for that model?
    The stove body is the same part, ceramic burner (may need), Pilot Assembly (may need), Regulator (definitely).
    Why can't that work?
  4. gsspike Member
    Remember we are talking about a $1200-$1600 stove, made with heavy cast iron. Not a discount store $200 tin through away stove.
  5. DAKSY Super Moderator
    If it was fuel convertible, the parts would be listed for the conversion.
    The way VC is being run after a couple too many bankruptcies, you probably won't
    find an answer thru their techs. Hell, I can't even get the right parts for their
    bread-and-butter woodstoves.
    Either leave it, sell it or use it for a boat anchor.
    The manual says you CAN"T convert it.
    Of course, you can try to cob it together, it's your stove, but remember, even a
    factory-listed room-vented heater has a lot of undesirable features, & we'll
    be debating them til we're blue in the face, or til they're outlawed.
    There are newer, more efficient & SAFER units on the market.
    Get one & you won't look back.
    Your call...
    My $.02...
  6. gsspike Member
    I was a master tech for years in the auto industry. 99% of all cars say this car can ONLY run on this one particular fuel, nothing else.
    But I know that if I have a Gasoline powered pick up truck and I want to make it a diesel I can change the engine and make it a diesel or with modifications make it propane or natural gas. No were in the owners manuals, the service manual or plates and decals say it can be done.
    I know what the manual and plate say, you can only burn one fuel in this stove. that's because that is the type of burner ass. is in that particular stove.
    All I want to do is take out the burner and controls and swap them, all the other part are the same.
    Think out side the box
  7. Wood Heat Stoves Minister of Fire
    Nevada City, California
    well, Bob is a master tech in this industry
    you came here looking for knowledge, why not listen to our resident Pro??
    (whom i totally agree with almost always :) )
  8. k0wtz New Member
    missouri
    the parts alone will kill you in cost and if installed incorrectly it will kill you. take the advice and leave it where it is.
    good luck
    bob
  9. gsspike Member
    Did I ask what it cost? NO It's unlikely it will cost $1200-$1600
    So since you brought it up Lets Pretent I have a VC UVS27 Propane version. What will it cost to buy a ceramic heater, regulator and pilot assembly?
  10. gsspike Member
    (whom i totally agree with almost always :) )[/quote]
    Yes I did and I expected more than what the plate says. I know what it says and why.
    If every single part number on these two stoves are the same, including mounting
    brackets for the burner and controls. The only different parts are the burner and controls.
    So some one here try thinking on your own don't read or quote me the plate or manual it explain to me why it can't work with out killing me. I'll even have a propane expert instal the parts.
  11. jtp10181 Minister of Fire
    Madison, WI
    Here is the thing, most gas fireplaces are easily convertible because the mfg's understand a house might change gas types throughout its history. If I ran into a unit that specifically stated it was not convertible then I would not convert it, no matter if I knew how to or not.
    If you look at the manual that YOU posted. Page 20. Here is something interesting.
    UVS27M Firebox Assembly / NG 0002795
    UVS27M Firebox Assembly / LP 0002796
    Yes, that is the entire firebox.
    So unless you replace that it would not be safe for LP, which is why its not convertible.
    Besides that you will need at least a new regulator for the valve, burner orifice, pilot orifice. Not sure what else, I do not know much about Vent Free fireplaces, as they are not legal in this state.
  12. k0wtz New Member
    missouri
    there is more to it than that. all orfices have to be changed along with the other parts you mentiioned. then finding an installer that will accept all the liabilities for this work just wont be found.
    sell the stove or leave it there either way you will win.
    bob
  13. gsspike Member
    Exactly, so what does the firebox cost?
  14. Fsappo New Member
    Central NY
    Just stop screwing around. Either leave it at the house or ask someplace else about converting it. No one with a lick of sense is going to tell you how to do something that is the OPPOSITE of what the owners manual says to do.
  15. k0wtz New Member
    missouri
    AMEN
    bob
  16. jtp10181 Minister of Fire
    Madison, WI
    How am I supposed to know? Call a dealer or find it online.
  17. DAKSY Super Moderator
    X2. We are not here to fight you. We do this for our livelihoods.
    These products, when improperly installed, will KILL you.
    I'm out...
  18. k0wtz New Member
    missouri
    i think wisely he has given up on the conversion. now he is inquiring about the cost of a new one. there are webites regarding what you want to install and some real experts here to help you. look in your yellow pages for dealers and start looking. there will be lots of dicisions and issues for y0u to resolve as you move along.
    good luck
    bob
  19. gsspike Member
    No I haven't given up yet, but this could end it.
    Seriously guys you need to get out more! Have you seen those setups in Lowes
    or maybe Home Depot, the set up where you can turn your wood burning fireplace
    into a "Vent Free Gas Fireplace". They start around $359.00 depending on what
    size log set you want.
  20. jtp10181 Minister of Fire
    Madison, WI
    Some might be low in price because they are low in quality, or they do not have the features other models might have. There is also no dealer overhead costs, like an experienced staff and sales people. All they have to do is stick it on the shelf and it sells itself.
    Who is going to service it when you need warranty work?
    Who do you talk to if you have installation questions or problems?
    Vent free fireplaces are also not legal in this state, but they do have some sort of fireplaces at Home Depot, I do not pay attention to them.
    Why did you even bring that up anyway?
  21. k0wtz New Member
    missouri
    let me tell you i have a unvented gas heater and im getting rid of it. a continual odor in the house, plus extra humidity and when i wash the widows there is a black film on them and the cloth after washing just think we are breathing whatever that is i purchased it and didnt know better.
    i have since found a vermont castings vented gas heater and am waiting for warm weather to install it as i have to go up through the roof with a vent. the experts are trying to tell you something for free here and experience counts for a lot.
    bob
  22. gsspike Member
    No this isn't a fireplace I'm talking about, it's just a logset on a ceramic heater and controls that you slide into an existing wood fireplace.
    I was bringing it because it's almost the same thing I want to do but more dangerous as far as I'm concerned.
    No two hand built stone or masonry fire places are built exactly alike. They have a code to meet and that's it. At least my stove is built to a much closer standard, especially between the NG and LPG models.
    Service well I guess I've been lucky. I have never needed service. I clean it up every fall and maybe again in Jan or Feb.
  23. fueldude Member
    US
    As a hearth dealer that also runs a propane company, there is not a single propane company in the country that would service, let alone, install gas to a vent-free stove that has been covnerted. Not only is it against the mfg's rules, UL doesn't permit it, and it's illegal in many states. The combustion is different between the gases, and along with the regulators, pilots, orifces, burner, valve, etc... are entirely different for LP versus Natural.
    I've run into our local Natural Gas company converting LP VF appliances to Natural and our state's PSC doesn't approve either.
    They come fuel specific for a reason...
  24. gsspike Member
    I guess your state is a lot tougher than mine or we are both talking about 2 different things.
    Most gas appliances in my state can be converted by flipping over a valve or some similar steps. Are you living in the USA or did I join the wrong forum.
  25. fueldude Member
    US
    Vented units such as heating stoves, furnaces, etc...are no problem (we also shy away from vented gas logs, as we've found they are generally fuel specific as well). Change the orfices, and valve spring (sometimes entire valve) and you're good to go. Vent-Free is a totally different animal.
    And yes, I'm in the US.
