Happy new year all!
My plans for an EKO 40 Gasser fell through due to...financing issues...the issue being I m low on finances!
As such I have picked up a 1982 Viessmann Mono-f boiler 13130-03 (144,400 btu) in good shape for next to nothing. Only problem is the controler is missing. From the factory it came with a Honeywell Braukmann FR125 s automatic damper control which had a chain attached to the damper door on the bottom to control the combustion air
Does anyone know where or even if I can get a replacement?
Secondly, if I can't find a controller I thought I might control the draft manually until the boiler is hot and then run it full out to heat the house and charge the storage until the fuel is spent.
Do you think the boiler will overheat or will 800 gallon storage absorb the extra heat?
Seemed like a good idea at the time but I can't find the controler anywhere.
Any help is appreciated.
