Vigilant Glass Gasket Replacement Question
spolleypt Posted By spolleypt, Oct 31, 2013 at 10:28 PM
Thread Status:
  1. spolleypt
    spolleypt
    Member 2.
    NULL
    Oct 17, 2012
    35
    2
    Loc:
    Maine
    I noticed tonight that my gasket was gone on my VC Vigilant doors. Took apart glass and gasket fell apart, as glass almost fell out too. I noticed online rutland has "glass gasket" that is stick on 11/16ths, and VC has a vigilant glass gasket kit that is 3/16ths. Can someone tell me the correct gasket to use and how to replace. I assume it does not go on with stove cement like the griddle gasket. The glass seems to just rest in place, rather than have a channel for gasket.
    Thanks very much!
  2. DAKSY
    DAKSY
    Patriot Guard Rider Moderator 2.
    NULL
    Staff Member
    Dec 2, 2008
    6,651
    1,200
    Loc:
    Averill Park, NY, on Burden Lake II...
    The gasket in the doors for the glass seal is 3/16. It pretty much just sits between the glass & the door frame. It doesn't hurt to put a little dab of RTV silicone in the corners of the door pocket to hold the gasket in place while you're positioning the glass. Don't use a lot, or you'll just squeeze it out onto the glass...
  3. spolleypt
    spolleypt
    Member 2.
    NULL
    Oct 17, 2012
    35
    2
    Loc:
    Maine
    Thanks Bob, Can I assume using the self stick type gasket would also work fine if I can find the right size?
  4. DAKSY
    DAKSY
    NULL
    Staff Member
    Dec 2, 2008
    6,651
    1,200
    Loc:
    Probably, but I doubt you will find the right size. Besides, most self-adhesive or tape gasket is flat. You need round gasket so it will compress and form an airtight seal...
  5. spolleypt
    spolleypt
    Member 2.
    NULL
    Oct 17, 2012
    35
    2
    Loc:
    Maine
    Most helpful again. Thanks. I believe the previous owner used the self stick as it had a paper like backing, but there was definitively an air leak as the glass was blackening by the leaking gasket. Time to head out and see if I can find the 3/16 gasket rope. Tried local hardware but they only had Rutland 1/4 -->5/16 which is good for the griddle but too large for the door.
    Thanks Again
  6. DAKSY
    DAKSY
    NULL
    Staff Member
    Dec 2, 2008
    6,651
    1,200
    Loc:
    The griddle does take a 5/16 gasket, but it's an ARMORED 5/16. It's not the same fiberglas gasket as the rest of the stove takes...If you can't get the 3/16", you can probably make the 1/4" stuff work by stretching it slightly, but you'll have to work quickly to get it under compression before it pulls back...
  7. spolleypt
    spolleypt
    Member 2.
    NULL
    Oct 17, 2012
    35
    2
    Loc:
    Maine
    I found that the glass gasket kit generic at the hardware store and there 1/4-5/16ths gasket material worked for the glass and griddle respectively. Thanks for the help.
Thread Status:
