Vogelzang Thermostat
Kurlus
33
Honesdale, PA
All,
No pun intended but the dog ate my Thermostat.
She ate it right off the back of my VG-5790 and now it doesn't run, lol. So I'm looking to add an external thermostat.
Any suggestions? Seriously looking for a wireless Thermo that will work with my stove. I tried a non-wireless one in a pinch as it's been -11° here this past week but no matter how I hooked it up, it didn't work. Link posted below for the one I tried or can you jumper the Thermostat and not use it?
I run mine on manual but I haven't tried jumpering the Thermo b/c I don't want to screw up the stove ;)
http://www.homedepot.com/p/Honeywell-Economy-Heat-Cool-Manual-Thermostat-CT31A/100400017
Thanks in advance!
The RF is the transmitter. The REC is the receiver. You need both.
Reactions: Kurlus
All,
Thanks in advance!
Your shite out of luck, you can not use an aftermarket thermostat with that stove, you need to obtain a replacement from US Stove.
Reactions: Kurlus
Look in the manual for part numbers on page 22.
Item number 39 (Note: Not shown in the diagram on page 23).
  • VG5790.pdf
Reactions: Kurlus
I got it working in the meantime, I jumpered in a resistor. I saw 39 in the manual for a thermistor but it didn't indicate where it was located on the stove.
That's a temporary fix, but don't run the stove in 'auto' mode as the temporary fix will not send the correct temp reading to the stoves built-in thermostat and could cause big problems.
