I want to pull the trigger on an Englander wood furnace but it being EPA exempt bothers me.
Anyone know why this is? Does that make it a smoke dragon?
The Drolet furnace is certified but has no reviews that I can find which has scared me off I guessPretty much. For the life of me I can't understand why they haven't updated it to a clean burning design.
Thanks for all the info Owen!Most are 35:1 air/fuel ratio. There are a few that are certified (EPA)
http://www.newmacfurnaces.com/index...-section/116-solid-fuel-forced-air-furnaces-2
http://www.northerntool.com/shop/tools/NTESearch?storeId=6970&ipp=24&Ntt=7000+furnace
Thanks layne!!The Caddy and Mini Caddy are EPA certified as well as the Tundra from Drolet (Caddy firebox design). Napoleon also has a woodfurnace that's EPA certified. There are others that are tested to B415.10 standards if I recall that are also clean burners. The Kuuma Vaporfire is tested and proven a clean burner, it's just not certified. Luckily for many, more and more clean burning furnaces are coming to the market.
Thanks Mustash!!It is a 1200 unit, full manual control of the fire, simple blower thermostat / control, with no dedicated secondary burn. It will burn clean if you run it hot and have good dry wood.
It seems that I used about the same amount of wood with my Englander last year (freaking cold winter) as compared to other years with my 1994 stove with secondaries. The whole house was warmer last year, not just 1/2 the house like before. Ash management was much improved with an ash pan, which the stove did not have.
I also did not use the 850 cfm blower the Englander comes with, I dumped the heat into my rec room and had 1, 2 or both fans running, 4" muffin fans from dead pc's. Allmost no power usage, quiet, gentile hot air coming off the unit.
I was using the same 10" muffin fan & 6' duct that takes heat from the rec room and blows it into the far end of the house. The cooler return air naturally found it's way down the hallway & open staircase downstairs.
Do you have it hooked in your furnace at the main trunk? I have a duct line right above where I want the stove. I was wondering if that setup would worki have one of them englander furnaces, its nice because its not picky about what it burns and will heat 2500 sq feet with a blower thru your ducting easily. i wouldnt trade it for nothing.
