    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. ray milosh New Member
    Hi all,
    I have a 1993 Waterford Stanley. i have used it for 8 years for cooking, heating the water and heating the house. (The house is small, well insulated and has solar features, too..that's why I am able to heat it with such a small firebox). I live in central North Carolina.
    For the past few years, smoke seeps from under the left side of the cooktop on startup or if i damp it down too much. I have unsucessfully attempted to caulk it from the inside.
    I hestitate to pulll it all apart and redo everything, primarily because it works fine otherwise and I lack experience with disassembling and reassembling this stove.
    I wonder if that's the only way to fix it or if there is a simpler way. Anybody have any experience/advice/people I could call to ask questions?
    #1
    Helpful Sponsor Ads!
  2. A1Stoves.com Feeling the Heat
    Northern CA
    if you are sure the chimney is clean, then yes- its time to take the inside of the stove apart to clean the baffle.
    some waterford stoves have a removable cast top to access stove top bolts- to clean top of baffle
    others came apart from inside- warped or damaged parts can make this hard! sometimes easier to pull the flue pipe and clean thru the flue collar.
    luck :)
