212 degrees at the top of the chimney. So it really depends upon your chimney height and insulationIs 510 degrees F inside a double wall flue 4 feet above stovetop to cool? What's the lowest you can go before you get a weak smoldering smoky fire?
Thank you in advance.
Internal flue & chimney until exiting out the roof. Total height around 26 feet, give or take a foot. I have to use the key damper sometimes, like tonight, when it tried to sneak away to infinity and beyond..212 degrees at the top of the chimney. So it really depends upon your chimney height and insulation
What type and size of chimney?Internal flue & chimney until exiting out the roof. Total height around 26 feet, give or take a foot. I have to use the key damper sometimes, like tonight, when it tried to sneak away to infinity and beyond..
Well it's a 6" chimney, but I can't say as I know the specifics of the chimney proper. I'll see if I can find the invoice for it. It was installed new when I bought the stove, maybe in 2012 or 2013. If I recall, the thickness of it when I take the cap off for cleaning is a half inch anyway....What type and size of chimney?
Is it a prefab stainless chimneyWell it's a 6" chimney, but I can't say as I know the specifics of the chimney proper. I'll see if I can find the invoice for it. It was installed new when I bought the stove, maybe in 2012 or 2013. If I recall, the thickness of it when I take the cap off for cleaning is a half inch anyway....
Seems hot to me, when my stovetop temp is running 600 to 700 degrees center of, the double wall 1 foot from the stovetop is generall at half what the stove is and decreases incrementally. this has always been the rule with my Blaze King < King. Other BK owners may have different experiences, no problems here whatsoever.Is 510 degrees F inside a double wall flue 4 feet above stovetop to cool? What's the lowest you can go before you get a weak smoldering smoky fire?
They aren't running a blaze king. But regardless 510-520 could absolutely be to cool and causing creosote issues further up the chimney depending upon other factors.Seems hot to me, when my stovetop temp is running 600 to 700 degrees center of, the double wall 1 foot from the stovetop is generall at half what the stove is and decreases incrementally. this has always been the rule with my Blaze King < King. Other BK owners may have different experiences, no problems here whatsoever.
Not for a non-cat. It is not comparable. Parity between the stovepipe and the stovetop temp is often where we cruise.Seems hot to me, when my stovetop temp is running 600 to 700 degrees center of, the double wall 1 foot from the stovetop is generall at half what the stove is and decreases incrementally. this has always been the rule with my Blaze King < King. Other BK owners may have different experiences, no problems here whatsoever.
That can be scary for sure.Internal flue & chimney until exiting out the roof. Total height around 26 feet, give or take a foot. I have to use the key damper sometimes, like tonight, when it tried to sneak away to infinity and beyond..
So does an owner need probes all along the chimney or at the top or does an owner need to climb up on the roof and check the top of the chimney temp during a burn?They aren't running a blaze king. But regardless 510-520 could absolutely be to cool and causing creosote issues further up the chimney depending upon other factors.
No people need to monitor the buildup in their chimney untill they figure out what temps work for their system. I mean yes a probe at the top would be fantastic but it just isn't reasonable. And not needed after you figure out what your system needsSo does an owner need probes all along the chimney or at the top or does an owner need to climb up on the roof and check the top of the chimney temp during a burn?
So many variables. The simple purchase of a magnetic stove pipe temp gage on my single wall pipe showed why I had monthly creosote build up from the stove to wall section.No people need to monitor the buildup in their chimney untill they figure out what temps work for their system. I mean yes a probe at the top would be fantastic but it just isn't reasonable. And not needed after you figure out what your system needs
Yes with single wall a magnetic thermometer is all you need. That's all I have. But if you need double wall pipe a probe is needed. They work pretty much the same just probe will read higher because it is reading internal.So many variables. The simple purchase of a magnetic stove pipe temp gage on my single wall pipe showed why I had monthly creosote build up from the stove to wall section.
