What is this sound?
Gregwood
9
Connecticut
Posted a short video.
Sounds like a incoming helicopter.
Sometimes it will get so loud my dog will bark upstairs. Only way I can stop is to crack open door or dampen down the plate in flue pipe? Eventually will go away. Almost always does it on first fire up with lots of dry kindling and paper.
Stove is "whoofing." You have wood that is hot and outgassing, but there isn't enough oxygen entering the stove to burn it smoothly. As a result, it builds up fuel gasses, then gets enough oxygen and woof, then not enough air, wood has enough heat for wood gasses to build, finally gets air, and woof again.
Best way I can explain what I am hearing anyway.
you should start cutting back your air sooner or add a touch more air when you set it for overnight. hopefully you are not burning to low. you'll have creosote buildup
Overnight burn isnt the problem. It only happens on first fire every day. Or alot of small pieces. After that it's pretty good.
small pieces will gas off a lot at once prob to much for the air coming in. it's happened to me in my early years with too many small pieces of cut off oak floor from a new job install when i went to open the door the fire came out at me.
