Ok, this is probably a weird question but I would like to know about what temp. it would take for an old oak wood beam to burn ?? Just heat no open flame,is it possible? Any info would be great. Thanks
The reason why I'm asking is my friend put a make shift chimney for his garage. He has the black pipe running along block and into a stainless steel square chimney (not triple wall single) The stainless is against the oak beam that the trusses set on. He did put sheet metal over the wood so I guess it never is wood to the pipe but it just seams it could get very hot. The wood is approx. 6 feet from the stove.
Pyrolysis(sp) can turn the beam to tinder. Time it takes is like, how long to rust takes to work through a fender. If you have enough heat for normal operation of a stove six feet from the fire it might be as high as 1000 °C. Put the pipe next to the wood even with a sheet between and you have problems. Add to that the condition of the beam and it's moisture content and your friend could torch his building in a weekend. That is why distance to combustibles is so critical to not overlook.
The autoignition point of dry oak is 900 °F . But every time you get wood hot it lowers the future ignition point. A reaction called pyrolysis. So every time he gets that beam hot he lowers the autoignition point until one of these days that point is reached by the heat from the pipe. A process called "Holy @#%^ somebody dial 911!"
We had a mill burn down that was 100+ years old. It started when an employee left a trouble light (one of those portable lightbulb things with the cage over it) on a beam for about 24 hours. It was pine but you get the point... It wasn't THAT hot, but hot enough to start something that couldn't get put out. The whole thing was consumed and 3 floors down on the ground in an hour.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
