And just brushing the gunk down into the stove and scooping it out instead of having to pull it out every time is worth the cost of a liner all by itself.
ok didnt know that if that is the case line it no questions askedThe OP previously talked about a Hearthstone Clydesdale so I figure he is thinking insert.
In Canada it's law that a solid fuel chimney must match the flue collar of the said appliance.The reason is to improve draft and to maintain flue temperatures.You can imagine a 6" wood stov pipe/chimney venting 300* temps up a 20' chimney at the bottom temp is 300* and at the top temp is probably 200*,now take that 6"/300* combo and vent it in an 8" chimney and most people can understand that the larger diameter chimney will rob heat from your starting temp of 300* an at the top of this chimney the temperature will likely be 125*.The hotter the chimney the faster the rise of heat up the stack,therefor creating stronger more reliable pull/draft on the appliance resulting in improved wood burning performance
It will probably be ok but it would be much better if it was 6" to match the stove.Hmm. Would this mean if I have a chimney designed for a stove with an 8" flue (and with an 8" thimble) that I can't expect reliable draft performance if I get a stove with a 6" flue opening.?
It depends. Sometimes it will work out fine and sometimes not so good. If there is strong draft and the chimney is taller than the minimum and there are not a lot of 90 deg turns in the smoke path it may work out ok. For example, an 8" straight up, interior chimney of say 20 ft has a better chance of performing well than one that goesup from the stove 3 ft, then out the wall to outdoors and then up 12 ft.Hmm. Would this mean if I have a chimney designed for a stove with an 8" flue (and with an 8" thimble) that I can't expect reliable draft performance if I get a stove with a 6" flue opening.?
I think 8ball gave a great explanation what will happen with an oversized flue. You will cope with the increased loss of heat and therefore draft by leaving your air control open more which will send more heat up the stack. However, you may never be really aware that you burn more wood than needed. The most noticeable differences will be during startup when you may experience problems to establish proper draft and at the end of the burn when the draft may not be enough anymore to burn down the coals. Lower flue temps also mean more accumulation of creosote and therefore higher risk of chimney fires. Sweeping the flue more often would be a good idea. What kind of chimney are we talking about here? Single wall, double wall ...?
This is very true but only applies to inserts which is not the norm here and in many other areas as well. If it is an insert then it absolutely needs a liner a free standing stove going into a properly sized clay liner that is in good shape can be a perfectly good setup. Although an insulated liner will definatly work better.
It will probably work but i would work much better with a 6" liner
yes and i should have said if it has proper clearances8" flue in a 16" chimney means only 4" or one layer of brick at each side. Are you not usually recommending a full insulated liner in such a situation because there may not be enough clearance to combustibles on the outside?
Why that difference between stove and insert? Isn't a stove with a few ft of pipe connected to a masonry chimney not pretty much the same as an insert with a quick-connect?
