    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. slash2869 New Member
    Clackamas Or.
    This may be a dumb question but why are there two auger motors on Englander stoves?
    #1
    Helpful Sponsor Ads!
  2. imacman Minister of Fire
    Just the way they designed them.....it's an older design and they just stuck with it. Upper auger runs intermittent (and feeds the lower auger), while lower auger runs continously.
    You'd have to ask Mike Holton that question to get the actual answer. All the newer stoves they make (10-cpm, EP, PAH, etc) use a single auger design.
  3. smoke show Minister of Fire
    Pittsfield, Wi
    I believe their reasoning was less chance of burn back.
    I could be wrong.
  4. DexterDay Minister of Fire
    NE Ohio
    There is prob a few reasons... Burn back is a good one though. On a manual start unit, it allows you to start your pellets on the wear plate and have the comb blower running. Once those pellets light, the bottom auger starts to feed pellets.
    I'm sure Mike can answer this and shed light on it. But there is always good reasoning behind something of that nature. Especially considering Englanders R & D.
  5. SmokeyTheBear Minister of Fire
    Standish, ME
    It could have also been to avoid patent infringement.
  6. Don2222 Minister of Fire
    Salem NH
    Hello
    Yes, that is one reason and another reason according to Mike.
    They tried it with just the bottom horizontal auger and it jammed up alot.
    This is a pretty good system.
