So, I notice after sharpening a chain on the saw it leaves some metal filings on the chain (a little bit). Can you hit the bar and chain with some carb cleaner to clean things up a bit. I just worry about the little filing geting into the drive gear. Could you use brake cleaner I suppose as well? After your done and get back to running the saw...your chain will get oil back on it.....so no worries I'd imagine after gettting the filing and oil off after sharpening...right?
I would imagine this idea is good if you're in your shop.....but in the field.
