    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Skitheeast New Member
    The store we went to showed us the manufactures recommended liner and it was 5.5". I thought the same thing regarding the 6".
    #26
    Helpful Sponsor Ads!
  2. TMonter Minister of Fire
    Hayden, ID
    If it'll fit go with the 6-inch liner.
  3. velvetfoot Minister of Fire
    Sand Lake, NY
    I believe mine is a 6" liner.
  4. granpajohn Minister of Fire
    Central Maryland
    My method of converting SF area for high ceilings is to just divide your height by the normal 8'. e.g. for a 9' ceiling, 9/8 is 1.125 so your 1800 sf becomes 2025 sf. Basically 12.5%. If 10' ceiling, use 1.25.
    And, insulate the chimney if it is exterior. (and it will fit)
  5. Mr A Feeling the Heat
    N. California
    The narrow side of my clay flue liner was only 5.5" I.D. I bought ovalized liner with a oval to round adapter for the insert connection, paid a litle extra fgor an ovalized chimney cap. I went to a few hearth stores around my area, they all said the same thing, they dont' install blockoff plates or liner insulation. I wanted a blockoff plate but it was too difficult to install with the work room available. I stuffed roxul around the liner at the top of the chimney and called it good. The installers all said they used fiberglass insulation. Fiberglass can melt, I thought it not a good idea. They said the top of the flue is not hot enough to melt fiberglass insulation unless there was a chimney fire. i had success installing my own, it is pretty simple once the process is under stood. in the end, it is just a pipe running down the chimney to the insert
  6. Skitheeast New Member
    Thanks for the info. Greatly appreciated. I will be doing the liner myself with the help of a friend. Loolks like we will go with a 6" and wrap it in insulation. 12 x 12 clay flue - should be able to get it down pretty easy. Going to have to notch where shelf is to get past without interference. Where can I get that Roxul stuff? Couldn't you just stuff the roxul around the shelf area above the insert rather than do a block off plate?
    Thanks -
  7. granpajohn Minister of Fire
    Central Maryland
    Yes you can. But it is often easier to accomplish that when you put a plate or other rigid structure up there. Get a close look at your situation, then decide. Search the forum for "block off plate" and you will notice that some members have built some real nice BOPs...where no one but Santa Claus can see it. (Mine is in the "functional-not-pretty" category)
  8. Mr A Feeling the Heat
    N. California
    I would like to have a block off plate, just too difficult to get in. I understand the idea to be cutting off the heat to the mass of the masonry chimney structure. In my house, the chimney is still warming the living room, 18 hours after the fire went out. For quick heat, I guess no block plate is a disadvantage. It isn't very cold yet, I had all the windows open yesterday on a 60 degree day. The hall thermostat is still holding at 68 degrees after overnight temps in the 50's. Roxul was hard to find for me, Google Roxul, the company website has a list of suppliers. Also searching Roxul in the forums, there is a place mentioned in a thread that sells it by the batt for small quantities. I have 8 ,16"X48" insulation batts available from my garage. I had to buy a whole package of it from the building supply company, 80 miles away. I only used a few batts. You have plenty of room with a 12"x12" clay liner to wrap your liner in roxul. I would like to sell my 8 batts for $50. They are made for 2x4 stud bays, so they are 4 inches thick. More than enough to wrap your 25 ft liner when split into 2" batts. Better, thicker insulation than an insulation blanket, usually only 1/2" thick for a few hundred dollars. I also have a box of Thermix I need to get rid of, $25 plus shipping.
  9. mellow Minister of Fire
    Salisbury, MD
    Most of us get Roxul at Lowes. They can special order it in.
  10. Mr A Feeling the Heat
    N. California
    I wanted it today, when I got mine. I went to both Lowes and Home Depot service desks and they had no idea what I was talking about. The guys at Home Depot did their thing of asking up the chain for about 30 minutes, finally a guy said,"yea, we can order it". Still have to buy a full pack of 10 batts, and wait, and pay for shipping.
  11. Skitheeast New Member
    Hi everyone,
    We are waiting for the liner to come in. A friend who does masonry work ordered it through Olympia. Should be here in a few days. He suggested putting vermiculite, (everguard), down there rather than wrapping the liner in an insulating blanket. Said it would be cheaper. Any thoughts? I'm a little confused regarding the insulation around the stove in the firebox. I have a masonry chimney built a few years ago, sounds like people who insulated their firebox around the stove had a different firebox, or problems with old chimney. Wouldn't the block off plate with insulation above it as well as an insulated liner in the flue be sufficient? I would think the heat would stay in the firebox area pretty well once the unit has been goiing for a bit with a BOP and insulation above it?
  12. begreen Super Moderator
    South Puget Sound, WA
    Usually one only downsizes the liner if the chimney is tall or if the chimney flue is small. That doesn't seem to be the case here.
  13. mcerin New Member
  14. relevance New Member
    Hi,
    I just purchased a Lennox "Performer" insert and couldn't be happier with my purchase. It's heating my 1300 sq ft, 60 year old ranch with a suspect amount of insulation. I learned that the seams on a cast iron, if over fired too often become brittle, break down, leak and lose their efficiency. Welded steel doesn't have that problem. While cast iron has that really nice traditional look, the logic behind long lasting efficiency won me over.
    Matt
