Ducky said:Is there a reason why the stove pipes are shiny instead of painted?
cptoneleg said:Ducky said:Is there a reason why the stove pipes are shiny instead of painted?
Chrome won't get you home but it's my favorite color
Stump_Branch said:cptoneleg said:Ducky said:Is there a reason why the stove pipes are shiny instead of painted?
I may argue chrome isnt a cilor, but i can agree with the look.
Shiny due to a polished finish. Theres various degrees i think thats more the the typical 2b finish. Polish helps with weather resistant.
BrotherBart said:Repainting a twenty+ foot chimney every few years would be the ultimate PITA.
But I hear ya. I don't know why anodized black Class A isn't an option. Cost is my guess. It ain't a cheap process and the stuff costs enough already.
mhrischuk said:"Anodizing forms an oxide protective barrier on aluminum but if you form iron oxide over steel it will not protect it adequately, for that reason a different compound has to be developed.
MasterMech said:Wouldn't that be..... rust? :long:
BobUrban said:Actually it does help in some specific circumstances with steel - a controled rust called a patina or blueing(think gun barrels) is a form of controled rust used to protect the steel. I am an amature blacksmith and make custom knives of high cabon steel and a patina or hot blue will help a lot with corrosion resistance but I am thinking it would not do squat for steel that is being heated and cooled regularily. Anytime you introduce high temps to steel you introduce an areas that will corrode more quickly. This is evident with welding and a weld joint on exposed mild steel will begin to rust almost imedietly vs. the surounding steel. I add a patina to some of my knive by soaking in vinagar or even cutting a potato or onion.
Probably just some worthless information but it is an area I have experience with and I get so much information about the things I don't know much about here I thought I could share it.
Bob Urban
pen said:MasterMech said:Wouldn't that be..... rust? :long:
Sure is, for aluminum, the "rust" actually protects the rest of the material. With steel, that isn't the case.
pen
