Hi Everyone. This is my first post here. I have had a Majestic WMC36 for about 4 years that gets fairly frequent use. It is connected by 4" duct to outside for combustion air. I recently had reason to remove some drywall from around the fireplace (lowering the mantle for installation of flatscreen tv above) and noticed that, although the chimney cooling air duct was cold to the touch, the combustion air intake was not, with its damper lever (on the lower left front corner) in either position. I spoke to a tech at CFM (the Canadian manufacturer) about this, because I was wondering if it was because of the 1/4" - plus gaps between each of the glass panes. He told me that those fireplaces are not airtight - which I knew - and that they should be operated with the doors open, which makes no sense to me as you have to open the flue damper much wider to prevent smoking and consequently have little control of the fire. Does anyone know if there should be such gaps around the glass, and whether there is some sort of knockout plate for the air intake that should have been removed during installation?
Larry
Larry
