Hi all,
Question is how do you pallet burners stack the wood inside the stove and keep the temps under control. A friend told me stop by his Dads flooring shop. They had a ton of scrap wood, mainly drops from their flooring jobs. All the wood is 1" thick, by 4" wide. Some was 5" wide. The drops all vary in length, from "4 to some I have to cut at 17". However, most if it is approx 4"-6" in length. I have a full size truck bed full of it! Half is Hickory, the rest is walnut, and oak. Solid wood. Here is my problem,
Tonight I made a Stack of 6" and 4" for the back, and two 4" stack for the front.
The stove took off to 500, i closed everything, and it kept going to 650. I was getting nervious it wasn't going to stop! I only put in a medium load of wood. It stayed at 650 for an hour ! I think because there is so much more surface area with the small pieces that it burns super hot.
So is there a better way to stack this stuff to control it better? Or just load smaller loads?
Thanks
Thanks
