I still have an old hot water gas furnace on cast iron radiators (gravity fed) in a property no power required for any of it,i keep telling the tenant when the power goes out in winter ,he will be the only one with heat
The ones i grew up with did not either. One was in-set into the wall the other was a free stander about 2feet high. They both heated through convection.
Gas as a primary heat source usually needs power,for a fan or a water pump as well as an ignition source since they dont use pilot lights anymore. Of course single zone heaters may not need power. I had a vent free(other name for toxic room heater) gas wall heater.It kept shutting off due to low oxygen,scary,instructions said use it with a window open,?huh. Got rid of that in a hurry.
We heated the Old House exclusively with the two (NG) Lopi stoves in my signature. DV stoves don't need power as far as I know. The thermostat runs off millivolts the pilot produces, so even that doesn't need anything to power it. One stove (Heritage Bay) has a blower, the other doesn't. Power or not, it's not cold in there.
We heated for two years prior to getting the Heritage Bay with a vent free and never had a problem. No moisture build up, no low O2 shut offs, no "soot" on walls. We use the Cedar Ridge one in my sig as well as a second blue flame in the utility area as back ups in case something happens and we can't get home to load the stove-pipes won't freeze at least. Of course, the Old House and the Cottage aren't exactly "tight" so that helps.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
