I have a Kozyheat ZC fireplace which must be installed with an OAK (according to installation manual).
I did just that but I veered from the manual just a bit because there was no easy option for installing the OAK in my house without going up with it. So my OAK is routed right along the chimney, and terminates in the attic space.
When my secondaries ignite (it takes them a while) they never burn on the first 4 inches or so of the tubes. I think that is because the Kozyheat does not pre-heat the secondary air, it just comes straight in, and it is cold. While working in the attic over the weekend it occurred to me, my intake terminates right beside the chimney in the attic space. Would it be beneficial to harvest the waste heat coming off the outside of the class A chimney to preheat the intake air?
It could potentially increase heat output by a slight amount because the intake air won't be as cold and the burn will be more efficient.
My thought is to put a 12" duct around the chimney leaving the top open (just like the insulation shield only higher) and connect the OAK to the duct. This would pass the intake air over the surface of the chimney before going to the fireplace.
Any thoughts/discussion? Am I wasting my time? I just can't stand to see good heat (coming off the outside of the chimney) go to waste in the attic space when there is a potential to improve the heating to my home.
