Here we go, been running the new XXV since mid-October, it has been performing just fine all this time. I'm fanatical about cleaning, it is done weekly and very thoroughly. I run my stove in room temp using a Honeywell thermostat, last evening it started as I was working in another room and after a while I said to myself this thing is taking a while to get going so I went to take a peek. To my dismay the glass was very very black, very lazy flame, the exhaust pipe was cold to the feel, pellets dropping off the burn pot half burnt. So I go outside and disconnect the vent at the T to look inside, no obstructions whatsoever. I shut her down, and when she was cold I inspected inside, black everywhere, black goo here and there, and smelly like hell (see pics). This morning I conducted an inspection of all the passages with my Rigid camera scope and the air inlet tunnel is clean, the exhaust tunnel is clean all the way to the fan, and from last night's inspection I know the vent is clean, so what gives here??? I connected my draft gauge(Dwyer 2302) and recorded the readings with and without the OAK, here are the readings:
without OAK, .75 on startup and .70 on low
with OAK, .90 on startup and .85 on low
My OAK is from 3 inch to 2 as the thimble supplied has a 2 inch hole I purchased an automotive exhaust reducer 3 to 2. Is this the source of my problem? if so why now? Draft on a Harman stove is supposed to be between .35 and .45
Should I increase my OAK size? and then adjust the draft correctly. What else should I look at?
