    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Backwoods Savage Minister of Fire
    Michigan
    Dave, you are right and if we did not have the time then we would stack in single rows. I've stacked in single, double, triple and more. I think the most rows I ever stacked together was around 25-30 or somewhere in that area. It all had plenty of time to dry and was all good. However, I don't normally stack that much together but won't hesitate if the need arises.
    Clutter, you are right about dragging those logs out with the tractor. Saves a lot of work but just beware of dirt on the log. You can always roll the log over and scrape the dirt off before cutting so you won't have to spend so much time sharpening the chain. A wire brush works great for this.
    #51
    Helpful Sponsor Ads!
  2. Cluttermagnet Minister of Fire
    Mid Atlantic
    Thanks, guys. Well, of course I'll be splitting all of that 1.5 cords of rounds very soon now. When I stack, you all now have me 'trained' to automatically allow a little breathing space between courses of wood. In time I think I'll get more into the practice of running a single stack all along the property line. For now, it's more like 'cubes' on pallets, but with at least some room between rows. In the photos above you can also see some of those rows of splits in the background. I have maybe 4-6 inches between those rows, accomplished with longer pieces that reach out to touch the next row, placed randomly as I stack.
    If you refer back one page, those bigger 'cubes' of Red Oak were put up with criss cross stacking through and through- also there are spaces between the three cubes. I suspect that pile is able to breathe pretty good actually, just not as good as single rows do.
  3. Cluttermagnet Minister of Fire
    Mid Atlantic
    You're right, Dennis. One tree still left there, probably a Red Oak, was actually dragged out of the creek. I use sticks and a wire brush to clean it up and try to minimize the damage to my cutters. Still, I do see the occasional sparks fly, and I know it's hard on the chain. I plan to have to sharpen a little more often when I work with the ground contact stuff.
    OTOH that old Locust I pulled out of there was horizontal but mostly off the ground, and it was just beautiful wood in every sense. Not very difficult to cut it up because it was clean and dry, with the bark mostly gone.
  4. Cluttermagnet Minister of Fire
    Mid Atlantic
    PapaDave-
    It's been two years now, and I will probably try a little of the wood from those 'cubes' this season. It's a nice feeling to know that I have enough seasoned for the coming winter. In fact, I'm probably somewhere between 2-3 years ahead. We keep having cold spells and I burn more than expected.
    [IMG]
