    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. kentjw New Member
    Central MA
    The feed trim button on my York does not seem to work anymore. This button is used to control the #1 setting and I like to have the 1 and 5 lights on as this is the high setting for the lowest heat level. Any suggestions?
    #1
    Helpful Sponsor Ads!
  2. jtakeman Minister of Fire
    Northwestern CT.
    These buttons on the panels seem to wear out over time. Do you have a multimeter to test the buttons continuity?
    If there is no connection you could change the button on the board. But you would need to have soldering skills to do so. And a good pair of eyes to see the little connection points. It can be done, But its tricky!
