    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. trekker New Member
    NW Ohio
    Is there a company that sells a zero clearance box that can be installed after removal of a heatilator and then fitted with a wood burning insert. I've been stumped trying to find an insert that will work with my heatilator due to size, and weight issues. Now I'm convinced I need to either find an empty ZC box(for an insert), or build a new firebox(with insert) to replace the heatilator. I live in a woods, and need to find a way to utilize my free fuel source. I live in a tri level, so the different level ceilings kinda rule out a freestander. I had a Central Boiler dealer come out, and give me a qoute but he was way high. My options are thinning quickly. Thanks for all the help so far.
    The Saga continues.
    #1
    Helpful Sponsor Ads!
  2. jtp10181 Minister of Fire
    Madison, WI
    Why would you want an insert if you rip the whole thing out? Get a built-in unit
    http://quadrafire.com/Products/Wood_Burning/Wood_Model.asp?f=7100fp
    If your Heatilator box uses SL300 series venting you might be able to tear it out and save the pipe in the walls, then hook the 7100FP or Heat & Glo Northstar to the same vent because it also uses SL300. We have done this a few times in the past and it works pretty well. Saves the customer a lot of money because the chimney can be expensive.
    Edit: I just downloaded the manual for the EL42 and it uses SL300 pipe.
  3. velvetfoot Minister of Fire
    Sand Lake, NY
    Hey that answers my questions on the other thread!
    That 7100 should be an awesome unit.
    Are people generally happy with it?
  4. trekker New Member
    NW Ohio
    You'll have to excuse my ignorance, but what makes these two models more efficent than other fireplaces?
  5. DiscoInferno Minister of Fire
    They are EPA certified, with controlled primary air and secondary combustion chambers. They are really just modern wood stoves inside an insulated metal box, same as an insert but made to go next to framing. They only look like fireplaces. There are lots of models and lots of threads on here about EPA ZC units.
  6. jtp10181 Minister of Fire
    Madison, WI
    No one around here ever complains about the 7100 or Northstar unless they aren't using it right, then I go set them straight. We install probably on average 2 a month for the last couple of years.
  7. trekker New Member
    NW Ohio
    So do these things mount in the wall just like my heatilator?
    If so, I think I've got my solution.
  8. jtp10181 Minister of Fire
    Madison, WI
    Yeap they do, look at the pictures on the site.
  9. scfa99 New Member
    New Jersey, USA
    velvet I love mine. ping me if you have any questions, i also have a lot of posts on it and pictures, just do a search.
    matt
Thread Status:
