Backstory:
12hp briggs i/c gold in a rear engine crapsman tractor
Tractor was running fine early this spring, then the ring gear stripped out. I parked the tactor and used a push mower the rest of the season.
Last week I finally get the time to swap in a new ring and starter gear.
I have compression (60 psi, but that sounds low) spark and tons of fuel (enough that it is spraying out of the muffler).
Now what happened? Did the valves go out of adjustment while it was sitting? or did my replacement of the ring gear, and quarter turn of the engine the wrong way make the timing chain slip?
I will be pulling the valve cover this weekend to look for something remarkable...
