- Oct 3, 2007
- 1,539
I had been fooling around with pole barn ideas a while back and then the wife told me she was pregnant
, so I got a little distracted for about 9 months. Now the little bundle of joy is here and I'm once again thinking about building something next summer. I basically figured out that for a structure this small, pole construction really doesn't make sense from a cost perspective, so I'll be stick framing this one, with a few twists... Basically I'm looking to create a 16' x 24' shed with a loft (10' x 16') at either end. The lofts will not only provide storage, but hopefully tie the walls together, since the braced rafter design of the gambrel roof with be imparting thrust on the walls. They'll also be balloon framed in so as to provide more headroom up top:
I showed this drawing to my local code inspector whose reply was "Yup, looks good."
I want to be sure that I'm designing a building that is going to be strong and long lasting, so I'd like a few more eyes on the design. I should mention though that the braced rafter design is a copy of what many shed companies/kit suppliers use in my area. Using 2 x 6 rafters and (in my opinion) very small gussets on only one side of the rafter, they rate them for 30lbs/psf snow load and 90 mph wind load. My gussets will be 3/4" plywood on both sides with the 2x6 sandwiched in between and will also be a great deal larger. I could also upgrade to 2 x 8s for not much more money. Does this look like a solid design?
The other loft will end up being some combination of storage, a couple of stools/chairs, maybe a small card table, and some sort of liquor cabinet. Over time I may develop it into more once I run electric out there, insulate it, and find a way to heat it that my insurance company will allow.
