Thank you so much for pointing out the model Nighthawk! I thought I had looked those stickers throughly, but I guess not good enough, lol.I just bought a double wide in Roseburg, Oregon and it has a Luap wood stove. Mine is a Convector 1. Yours is a Nighthawk according to the fine print on your emissions sticker. It is in the second to the last line.
Having grown up in Wisconsin and then spending 20 years in Idaho, I was familiar with Fisher, I was familiar with Blaze King and Earth Stove and some of the other bigger manufacturers, but the Luap was new to me. For a stove that predates the air tube technology, I'm very pleased with what a great stove this is. Though mine is called the Convector, it appears I may be able to add a blower to it based on the opening for the air passage that goes through the jacket and comes out above the lower step on the top. That's what motivated me to start looking online.
I haven't cleaned mine up yet, the move into the house has required my attention on more critical issues.
I have enjoyed reading this thread and seeing your progress.
We have a Convector stove that we bought new in '85 or '86, we still use it each winter and it works quiet well. It's burn a many cord of wood. It looks almost identical except the damper control on ours is on the right side below the door handle, looks like yours is in the middle under the ash catch tray. As for a fan to assist...if needed we have set a small fan behind the stove on the floor and forced air in the back, it will exit through the screen that is between the two flat tops. I still have all the paperwork that came with ours somewhere.I just bought a double wide in Roseburg, Oregon and it has a Luap wood stove. Mine is a Convector 1. Yours is a Nighthawk according to the fine print on your emissions sticker. It is in the second to the last line.
Hi Terrydk,We have a Convector stove that we bought new in '85 or '86, we still use it each winter and it works quiet well. It's burn a many cord of wood. It looks almost identical except the damper control on ours is on the right side below the door handle, looks like yours is in the middle under the ash catch tray. As for a fan to assist...if needed we have set a small fan behind the stove on the floor and forced air in the back, it will exit through the screen that is between the two flat tops. I still have all the paperwork that came with ours somewhere.
Thank you so much.The damper is closed when the handle is pushed all the way in. Damper is wide open when its pulled all the way out. I have all the paperwork including a brochure somewhere just need to look for it. The air from the damper enters on the sides just behind the glass in the door. The idea being that the air flow keeps smoke off the glass. If you open the door and shine a flashlight into that slot on the right side above the damper handle you can see the damper handle moving. The damper works well and will snuff the fire completely out if pushed all the way in.
