My 25-pdvc has a manufacturer date of 06/20. It's been installed for 2 weeks. The first week, it ran fine. I did not officially live here so I never got to start it up. Upon moving in, the top auger no longer feeds. I cleaned out the hopper and tested the auger by swapping lower and upper leads. It ran, so I know it works. Now, I finally got it to run on the normal leads, but upon closing the hopper door, it immediately stops. The leads are all where they should be according to the diagram. The stove lights but never leaves startup. I believe that's because it doesn't continue to feed pellets. The switch is plugged into the NO port, but the attachment is kind of bent down, I'm not sure if that's normal. I started up the pellet stove and held down the safety switch and there was no movement. I pressed the button a few times and I heard a small zap then the top auger started running. So I closed the lid and it stopped running. Do I ha e a bad switch all together? Or am I missing something? This is my first time ever having a pellet stove and I'm ready to chuck this thing out the window. It's still under warranty but that would mean we'd be without a source of heat (not like we currently have one) for at least a week or more. So I'm desperately trying to fix this myself.
