Al20-4c will give you better life on a 50-50 mix but having said that, I've been running standard pellet vent (Simpson) for the last 10 consecutive years on a 50-50 mix with no adverse side effects and no internal corrosion and this is why I think it works for me...
I may run at lower feeds depending on ambient and that may or may not cause condensation in the inner liner but prior to spring shutdown, I go to straight pellets for a couple weeks and run it balls out just prior to shutdown (at the expense of sweating with the windows open)......., but that drives off any remaining moisture/condensation, then I shut it down, clean the appliance and the venting, using the leaf blower scenario and a careful cleaning of the stove itself.
Like I said, 10+ years on standard Simpson pellet venting, no corrosion issues, something I was initially concerned about myself....
I believe my regimen is also good for th stove interior and exhaust path as well.  The stove can suffer corrosion issues as much as the venting if left damp because the nitric acid vapor needs moisture to corrode metal, not just stainless.  Additionally, the higher the RM is of the corn you are combusting, the more nitric it liberates as it burns.
After 10+ years, I have a slight corrosion etching in the stove interior but nothing that compromises operation.  When I do shut it down and clean it, the very last thing I do is fog the stove interior (with the CA fan on high) and I have to make sure the hopper is devoid pf pellets to do that,  to pull the fogging oil throughout the stove and into the exhaust venting.  I use Stabil Engine Fogging oil in an aersol can but I've heard that PAM cooking spray works well too.
Hope that helps you.
