I have a Tarm solo40 with a 500 gallons pressurized propane storage tank. Reading some other posts about the rather short life expectency of these boilers, whats the best way to check and adjust if necessary the boiler water ph level?
chuck172 said:other posts about the rather short life expectency of these boilers, whats the best way to check and adjust if necessary the boiler water ph level?
broken link removed)DaveBP said:Does anyone out there know if boiler treatment chemicals have to be added to make the same % concentration as the system gets larger? Rhomar says add 1 gallon to 50 gallons of system volume. For a system with a 1000 gallon pressurized storage tank the total system volume could easily be over 1200 gallons. That's 24 gallons of chemical to add at a cost of about $2000!!
Or like some chemicals, is it enough to have a few pounds of the stuff floating around in there because it is intended to react with the metal surfaces which are an exponentially smaller percentage of the system volume as it gets larger. Adding more of the stuff shouldn't change the pH, it just increases the concentration of the ions.
I dropped out of the University of California in the middle of a chemistry class so maybe I missed that lecture.
OTOH, I’m not at all sure I like the idea of running lye into a system like JE mentioned, other than possibly as part of a clean and thorough flush afterwards cycle… Yes it will change the pH, but it’s also a powerfully nasty reagent, and I don’t know what there is in a system that would neutralize it so that it would’t attack the metals in it… NOT saying it’s “wrong” but I would want to see a lot of evidence that it’s a good approach.
mentioned, but is no more than a neutralizing reaction when performed properly. In other words, the lye is being used because the water pH is acidic, and the acidic water is neutralizing the lye. The formation of water is not the issue, but the question is whether the resulting compounds, based on the acids being neutralized, are an issue for corrosion, pitting, scale, cracking, etc. Since I'm not a chemist nor a metallurgist, I'm guessing the answer is complex.powerfully nasty reagent
