Hey guys/girls. I have been working with firewood all my life because I have to. I'm either a poor bloke, or just tight with my money, (haven't figured it out yet). Let's go with "I'm low on cash". I cut my wood in a very gnarly location a couple miles from where my stove is located, but its open country free to cut what I want. (I'm an heir to the property). My problem is transportation. Over the years erosion and traffic has turned this area into something like what you would see if you U-tube "insane hillclimb" or "bounty hole" or "hold my beer and watch this". A good standard 4x4 road truck used to work pretty good. Over time only atv's could pass. There just isn't much room to put firewood on a 300honda fourtrax and a cheap Lowe's trailer but even then the road got worse and started to become impassable. ( I started breaking trailer tongues and wiping out my swimg-arm bushings way more than I liked). I ran across an insane build on youtube of a home-made wood hauler powered by a 6.5 predator engine from Harbor Freight.
I know this idea works using an insane gear ratio to increase torque which basically means "its gonna be slowww". That is fine with me. I have a welder and can source the axles, steering gear, transmission and transfer case without much hassle. My question is this:
Using something a little more powerful such as a motorcycle engine, a larger 22hp lawnmower engine, etc and using a gear ratio that would give me 5mph top speed in overdrive 2wd um, High Gear, (im guessing 1/16 a mph in 4-low) do you think it would still have enough torque to move 4 full chords of split wood through some gnarly areas if the chassis was designed correctly? It basically has to be a rock-crawler with a huge cargo bay powered by a lawnmower engine, motorcycle, etc. What is your take on a build like this?
![[Hearth.com] 5hp Off-road redneck firewood hauler thoughts with background, would it really work FOR ME? [Hearth.com] 5hp Off-road redneck firewood hauler thoughts with background, would it really work FOR ME?](https://www.hearth.com/talk/data/attachments/293/293615-3a606ac1e24ed54c77330ea0fec7e2ba.jpg?hash=y_VMa5kx0d)
