I am planning to have a wood boiler installed for the upcoming heating season. Our existing oil-fired boiler heats water for our radiators and domestic use. Ideally, I would like to have a wood gasifier boiler with oil backup capability. Instead of firing with wood during the summer, I would probably let it use the oil backup for domestic hot water. In the summer, I prefer cool (or all cold, all the way, baby!
) showers anyway. Our hot water needs during the summer are minimal. Another thought was to install a wood-only boiler (with domestic coil) and a tankless natural gas-fired water heater (domestic hot water only; used when not firing with wood). One concern about a wood-only boiler with no backup heat source is that it would limit our winter travel (think frozen pipes) and it wouldn't be a selling point if/when we decide to sell our place.
I'm considering leaving our oil-fired boiler installed and install a second, add-on wood boiler, though I'd rather not give up the additional space. I was also under the impression I would need separate flues for the installed oil boiler and an add-on wood boiler. I mentioned this to a friend that has some experience with heating. He indicated that a separate flue isn't mandatory, but that the flue needs to be sized properly for all appliances connected.
So, does anyone have a good source for a used wood boiler (optionally a gasifier) with oil backup?
I'm watching (broken link removed to http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=250835551492&viewitem;=&sspagename=STRK:MEWAX:IT#ht_1122wt_905), not sure what to think.
Responses to the thoughts on single appliance per flue?
General thoughts?
Thank you!
) showers anyway. Our hot water needs during the summer are minimal. Another thought was to install a wood-only boiler (with domestic coil) and a tankless natural gas-fired water heater (domestic hot water only; used when not firing with wood). One concern about a wood-only boiler with no backup heat source is that it would limit our winter travel (think frozen pipes) and it wouldn't be a selling point if/when we decide to sell our place.I'm considering leaving our oil-fired boiler installed and install a second, add-on wood boiler, though I'd rather not give up the additional space. I was also under the impression I would need separate flues for the installed oil boiler and an add-on wood boiler. I mentioned this to a friend that has some experience with heating. He indicated that a separate flue isn't mandatory, but that the flue needs to be sized properly for all appliances connected.
General thoughts?
Thank you!
