I'm planning on installing a class a kit by Selkirk/Supervent. Let's see if I got this right or not.
1. The wall cutout should give 2" clearance around the pipe to combustibles, ie sheetrock on the inside and sheathing/siding on the exterior. This would mean a 10" cutout for 6" pipe or larger depending on the OD of the pipe.
2. With a 2x4 stick built house does 9" pipe length through the wall cover 3 1/2" framing, 1/2" sheet rock and about 1" in sheathing/siding on the exterior. That's 5", so since I need 3" inside, that's a total of 8" so that leaves me 1", but the exterior wall bracket keeps the chimney pipe 2" away from the exterior wall. Is there some room on the Tee that gives you and inch or two.
3. I was reading the installation guide for several stoves and they recommend 9-12" of clearance to combustibles on the cutout. Does the wall thimble with the exterior wall plate, interior wall spacer and class-a chimney pipe reduce the clearance to 2"?
3. I'm heading out this weekend to pick up all the pipe and don't want to make the 30 mile trip more than once.
Ed
PS I've got a good deal ($1800)on a VC Intrepid in blue, but I also saw the SUmmers Heat stove at Lowes for $350. My wife is leaning towards the VC for aesthetics, but at $350 the lowes is tempting.
Ed
