Add on wood furnace or Wood/oil combo?
11
I am planning on buying a wood furnace very soon and I was looking for some advice. I have an existing old (mid 80's) Thermopride oil fired forced hot air furnace, along with AC. My question is, would you guys replace the entire unit with a combo or just add an "add on" unit?
What are your alternatives to oil where you are at (where are you at?), and do you use oil for anything else?
I am in Connecticut. I only use oil for the furnace. I have access to anything, such as LP, NG, pellets, etc. I burn wood now and I have pretty much unlimited access to it.
(broken link removed)
The smaller of the two furnaces would be a simple installation , the oil with its AC remaining your back up .
Reactions: lampmfg
How do you heat your hot water - and what kind of shape is your a/c unit?
I guess my main thoughts now are - I think I would keep the units separate and add on a wood unit. And depending on the rest of the situation, maybe even turf the oil all together in favour of perhaps a new NG unit, or maybe even a heat pump that would replace both your oil furnace and your a/c unit. Just make sure you consider EVERYTHING that you can to set yourself up long term.
