looking to add a fan to ash door for stoking fire on hot blast 1557m
the reason i am looking to do this is because, to extend burn times at night i close the stove damper almost closed. burns good and long but my house will slowly cool down at night and in the morning my stove still has plenty of wood( coal is going out because i dont have enough air even with damper open all the way not enough draft) but my house is only 64-65 degrees in the morning while not bad downstairs it makes it really cold upstairs cause with my drafty house it cools down fast
the plan was to use a wall mounted thermostat for contoling baseboard electric heat (110v) to control a draft inducer fan mounted on the ash door to get fire hotter when it gets below a certain temp upstairs say 67 it will kick fan on and blow to heat fire up till it gets above that in the house then the fan will shut off my blower fans for the ductwork kick on when the stove reaches 120 and kick off when it cools to 90(snap disc thermostat)
let me know your ideas if this sounds stupid or any advice on how this will or wont work mainly looking to do this for coal wood i can keep it pretty close to 67-68 when i get up if i fill it full when i go to bed at 2-3 but coal goes out cause i dont get it enough air
