I am about ready to pull the trigger on an EKO 40 (from Cozy Heat) and am needing some advice on water storage.
I would like to do this right the 1st time. So storage is needed in order to get the best efficiency
2400 sq ft (1200 basement and 1200 1st floor)on 1 forced air HX
900 sq ft on second forced air HX located on 2nd floor
Lots of double pane casement windows on 1st floor
DHW
Approx 40kBTU - 50kBTU load as done from calculator on Alternative eating System's site
(broken link removed)
As I understand it from other posts, Pressurized Storage greatly reduces the potential oxidization issues. However, my space limits me to a 500gal propane tank(which i should be able to pick up for $100.00 - $150.00). After doing the calculations, in the EKO manual, I see that this is about the minimum starting point for storage.
I have seen that some of you guys are "stacking" 500gal tanks. I am not sure if that will work for me. I will have to figure out how much clearance is needed between the tanks. I have about 8' to the bottom of the floor joists.
This brings me to un-pressurized vessels / systems.
What precautions need to be taken to stave off corrosion?
Has anyone done a plastic tanks such as these?
http://www.kentuckytank.com/index.html
I have not called them yet(as it is Sunday) and asked about the ability to hold water at 180+ degF or the price. I know that STSS tanks are pricey on Cozy Heat's site Perhaps this is why I have never come across this method in my search of the forum.
There is something that scares me about building a box in the basement and filling it up with 1000 gal of water, although i might have to get over this fear because I see that several folks have done just that. I am just trying to get some other ideas for "store bought" tanks.
DHW
