after cleaning problem
  • Thread starter Thread starter Trophy_67
  • Start date Start date
T
Trophy_67
Guest
Did a total cleaning this morning since I have burned a little over a ton .....got all the knooks an crannies but I f'ed up when removing the Combustion blower, on my Englander the thermocouple for the combustion fan is mounted at the exhaust after the fan,when removing the fan assy. I undid the thermocouple but I guess I pulled on the wires just enough to pull the opposite end out of the Control pad..so when I restarted she got HOT an THEN OVERHEATED went into shut down mode since the unit didnt know it had a fire in it ..well NOW I KNOW THAT PART WORKS.
I had to unscrew the control pad to get a hand on it and plug it back in ..the plug in seems to be awful loose ....would it hurt anything to apply a little epoxy to the outside of the control pad/thermocouple plug to keep it from coming out so easy ?
THOUGHTS PLEASE?
THOUGHTS PLEASE?
You don't really want to glue things like that together, the plug setup is there so you can take things apart and replace just part of the system.
