#1 I've read my manual, I've read forum news articles and forum posts. I get that an inch border to the ash line on the burn pot is cool. My stove hasn't seen that yet. Is that just a test location when run on full out as the article indicates or are you guys striving for this in normal run mode ? I have increased my feed to about 3.75, the flame seems thicker and the house temp seems to rise more quickly than on the lower setting I had it at. Leads me to question 2.
#2 My dealer said that I could run the P61 at feed rate 4. In stove temp I was unsure about that setting and found what I thought was good at 3.5. Then I changed pellets and went to room temp manual mode and down to feed rate 3. Does feed rate directly relate to pellet use differences between these two modes ?
#3 Fan speed. I'm running the stove between low fan and medium. I seem to get the best distribution throughout the house there. However the stove will take off with a high fan regardless of a lower setting sometimes. I assume it's just evacuation of high temps building in the stove. Or should I turn it to low ? This is in room temp manual as well. I'm off stove temp now have been for two full days now.
Thanks for any and all insight ! Yes I read the FAQ above.
