I was given this old stove by a friend who no longer wanted it due to his homeowners insurance so I put it in my garage. For code the firebox had to be 16" off the floor so cinder blocks worked perfect. It went through more wood than normal this winter so I started hunting for information on the internet and found this forum on Hearth.com.
You guys are fantastic! What I've learned in a couple hours is immeasurable! I had some 5/16 and will make a baffle but looking inside the firebox raises a few questions.
A second row of brick is apparently in use but the corners are all that remain on this one. Do I run them all across the back before installing the baffle? Is the second row even necessary?
I plan to use a masonry saw to angle cut the support bricks on each side; What angle do you recommend?
It's 25 1/2 across so I'm guessing this is a Grandma. I have the screen but have never used it. The door handle knobs are wood and the right handle is bent. I don't know if that was from extreme heat or age but they look original.
The air damper on the right is also very loose like the threads are worn down. Is it worth trying to replace the bolt? It appears to be welded in place.
Would I benefit from installing an air deflector plate inside each damper to further stir up the intake air?
The doors look different from any I've found so far on your site. Any idea of the age of this stove? I can't locate any identifying numbers on it but as you can see it needs a good cleaning.
Thank you for all the information you make available to us, any and all assistance you can provide would be appreciated.
Mike![[Hearth.com] An old Fisher [Hearth.com] An old Fisher](https://www.hearth.com/talk/data/attachments/178/178538-6c29038dd0f89a886dfa520978d40174.jpg?hash=eXwsXPI4r2)
 ![[Hearth.com] An old Fisher [Hearth.com] An old Fisher](https://www.hearth.com/talk/data/attachments/178/178539-42f31f1a7d6b7bd82793cf6ada504ebd.jpg?hash=0dn4x4e5OR)
 ![[Hearth.com] An old Fisher [Hearth.com] An old Fisher](https://www.hearth.com/talk/data/attachments/178/178540-4b0f0cd74633f438886bee320221d350.jpg?hash=gi4oWL25Nt)
 ![[Hearth.com] An old Fisher [Hearth.com] An old Fisher](https://www.hearth.com/talk/data/attachments/178/178541-8048fe4a44dfc41626f2589b8cc5db95.jpg?hash=NZB6C0FNKH)
Mike
