Any info on Farmtrac 320dtc?
oilstinks
586
western NC
I inherited a farmtrac LG 320dtc. Figured it would be good to pull a few logs. It is 4wd but has turf(ish) tires. Problem is I can find so little info on them on the net. Looking for any info I can at all. I have no owners manual so anything would help especially fluid specs. I know the clutch is only about 50hr old after being replaced at 300ish in my garage . Came with 5ft bush hog, single plow and a box blade but no FEL. I found an online parts breakdown but that's absolutely it. I know it has the Daedong 3cyl engine. Hoping someone here has one of these little compact tractors. Thanks all.
Pics please. >> I won't be much help, but I can look at pics.
This is a net pic. Exactly like this but not as clean lol.
Reactions: andym
The site has been very helpful over the years with info for the various machines I've had.
I have a new to me 1988 John Deere 240 and it has a 42" single stage snow thrower on it.. with sections for each maker it's easy to find out info for your machines . The JD section has given me some great info .. ==c
If its has the daedong engine, it could be very close to a kioti tractor
Reactions: SpaceBus
This may help.
farmtrac- that name has morphed several times, Likely similar to Northern tools unit and about 4 or five others that are rebadged. right now the oem escapes me likely pop into my tiny bit of gray matter later . TYM made a lot of sub market units under different names before they entered the market with the own brand- still do also. New Holland is one. Could be a JIMA also. A lot of those came in as Grey market units under different names.
Reactions: duramaxman05
I know my Kioti tractor uses a Daeodong three cylinder turbo if that helps.
I believe Lg turned into LS and. Mine is actually badged LG. I can't verify but a feel a lot of the India, Korea, and Japan designed tractors may come from the same manufacturer with either daedong or mitsu engines.
Farmtrac North America- bankrupt 2008 , Purchashed by Montana tractors. Farmtrac originally a division of Escort AGI out of India. I think JIMA is also from India. I do not know if Montana tractors are still around, or became some other name.
The ROPS is throwing me off when trying to find what kind of badge job it is. Not sure I've seen any other tractor with a simple U shape like that.
Wont fit in my shop with the standard size garage door. Need to ponder a folding one.
