I am getting good heat on these cold nights in the teens with my setting on room temp set at 80 - 85 feed 5.5.
Does anyone see a problem doing this? I know some will say just run it in stove mode. I have tryed to do this but for some reason when in stove mode I have to keep dial on 85 or #6 to keep heat up.Just doesnt seem to burn the same in stove mode looks and heats better in room temp.The hand held gauge at the room temp probe never gets over 70.5 anyway so keeping it in room mode it still runs constant unless I drop temp down. Again I am heating 1,550 ft downstairs and about the same upstairs. Does anyone think 75 room temp setting and 85 roomtemp setting when probe area is only 70 makes a difference? I always thought stove only has a max feed of 40 on 20 off in a 1 min cycle? So in theory 75 should kick out the same heat as 85 setting as long as probe location is 70 or under.Please correct me if I am wrong or explain how this stove does anything different from a 75 setting vs an 85 setting when probe location temp is well below both settings.But here is the kicker.I do notice a difference in heat output when set at 75 vs 85 so I am confused.
I am able to keep stove room 71-72 kitchen 28 ft away 70 and backroom 42 ft away 67.5. My upstairs 70 in hall 67-68 in bedrooms.So I just want to know is there any harm running almost flat out with this stove?
