I have had an Ashley ap5660L for two years now, I bought it used to heat my garage. When I got the stove it was three years old and somewhat neglected. I think I have replaced nearly everything that has a motor or sensor (except control board thankfully ). Stove worked perfectly last season and this year I fired it up once temps dropped into 30’s. It started by throwing an E3 code after 30-40 min - turned out to be a bad low limit disk. I figured it was a good time to replace the not functioning ignitor. Purchased the new and improved (upgrade) ignitor , installed and the minute I turned the stove on from cold it tripped my breaker. After two tries I unplugged the ignitor and went back to manually starting the stove. Now I am noticing I am barely getting much heat one the highest setting. I have adjusted the damper to find a good setting. But honestly I feel like it is doing little to nothing for the fairly aggressive airflow. If I restrict the end of the intake I get a bit more of a yellow /orange flame that doesn’t appear like a torch. Perhaps the damper isn’t doing much. Did the usual inspection of all gaskets, door, burnpot etc all seem fine.
Thoughts on the ignitor and low heat output ?
