Ashpot gasket placement on a Harman advanced pellet stove please tnx new to the group
Not exactly sure what you mean. Are you referring to the BURN pot? If so, the gasket goes between the wall of the firebox & the burn pot body. IIRC, in order to remove/replace that gasket, there are 4 fasteners that need to be removed in order to detach the burn pot from the firebox wall. 2 at each top corner & 2 at each bottom corner. You will need a 1/4 “ drive socket wrench, a couple of universals & 1 or 2 extension to get the lower ones out. Scrape any remaining gasket from the wall & the seating surface on the burn pot. Position the new gasket in the correct location & reattach the fasteners. Hope this helps.
Reactions: NS P-68
