I read that the grizzly model when in 4wd, the power steering turns off. That would be no good when the rock crawling starts. I'm not sure if its the newer models though.
My Grizzly doesn't know about that so it just keeps on working in 4wd.
Don't overlooked the used market. Plenty of lightly used machines out there...not sure where you are located but these are pretty common...usually guys trading up to a side-by-side:
(broken link removed to http://philadelphia.craigslist.org/mcy/3892893790.html)
That's about the same number of miles and hours I had on mine when I got it....not even broken in yet.
This
www.best-used-tractors.com/mini_truck.html[/quote]
If I could put one on the road
I'd had one by now,neighbor has one with a slow moving sign & a bag of feed in the back
I looked at new 2012 honda fourTrax rancher 420 AT w/eps. It was nice. I would like an automatic, which this is, along with the handle bar push button shift as well.
So far this model...
Likes
1. its a honda
2. gears, no belt (not that variable speed belts are bad)
3. It has 3 features I would like, downhill assist, power steering, ind rear suspension
4.its 1k-2k $ cheaper than the polaris sportsman 550 & yamaha 450 grizzly (which I may still purchase)
Dislikes
1. Ive read that the auto trans cant decide which gear to be in when going uphill with obstacles/dips, ect, leaving the rider to rely on the push button shift ( which will be a pain while needing my hands to maneuver.
2. Reverse is a pain, pulling button down after push button to neutal...
3. Lack of true waterproof storage
Next quads on my list are grizzly and sportsman
Everybody should get some side betting going, who knows what ill pick.........
It is both true auto with a semi auto standard option with the machine. Yes, thumb shift when not in auto mode.
I bought my brand new Rancher for less than that. I had a hard time finding a good used one personally.
Ok... How about that rear brake not sealed? Thoughts?
The rear disk brake is not sealed unlike say, the grizzly. And are the ranchers 3 eheel drive and not 4? Thx manRancher AT has disk brakes (2 in front, 1 in rear). What do you mean by not sealed?
Hondas don't have a locking front diff...so they may spin 3 or 4 tires depending on the difference in traction between the two front tires. Diff lock is one place Honda is behind the market...but unless you are doing extreme rock crawling or mud bogging it really isn't an issue.The rear disk brake is not sealed unlike say, the grizzly. And are the ranchers 3 eheel drive and not 4? Thx man
I don't know anything about sealed disk brakes.
What's the name of the dealer in TN?I bought my brand new Rancher for less than that. I had a hard time finding a good used one personally.
It is extremely rare that you run into a situation where you need all four tires pulling . . . and even then there is a trick on some Hondas . . . if you gently tap the brakes a few times you can lock things up a bit for extra pulling power.
Not sure about the sealed brakes either . . . I do know that I don't particularly care for my drum brakes and would much prefer disk brakes.
http://www.southernhonda.com/
I would encourage the OP to call there as well. They will give you their bottom line price up front over the phone.
I just called them, and they discounted (wholesale) the honda FourTrax Rancher AT w/electric power steering from the price up here in pa at $7500 to $5447.00! At those prices the wife wants one too. Added bonus, I work in logistics and can get a pallet rate of $140 each per quad to ship it carrier back here to pa! I will get more details monday, and who knows, I might do this! Thanks so much for that link!
We'll see what happens.... I'll do business with southern honda, but first I'll use my quote from them at the local dealers I'm dealing with up here. I dont think it will have much affect up here, but I'll still try. Keeping fingers crossed. I may pull the trigger later this week.
