auger trouble
kimwolfe
12
Pasadena, Maryland
I have a Whitfield profile 30. My auger will start to turn but then stops and won't feed pellets. I cleaned the eye and still not working. I bypassed eye and still not working. Checked auger motor turns fine with a power bypass. Im thinking its the high temperature sensor. Please help
Need help please
Does the high temp sensor have a little red button in the center?
[QfoundTE="heat seeker, post: 2058975, member: 17498"]Does the high temp sensor have a little red button in the center?[/QUOTE]
I think this is your manual
http://www.woodpelletheat.com/ProfileStoveManual.pdf
If your Fault light is flashing, check Problem 8 in Troubleshooting section.
If its not flashing, check Problem 3 in Troubleshooting.
It wouldn't let me copy/past.
Also it may appear that you have a PhotoEye Filter as well that needs cleaned.
I found the eye in the back of my stove but not the filter. Do you have any idea where its at?
Here we see the relevant troubleshooting sections:
[Hearth.com] auger trouble
The door switch could very well be the culprit, since it is placed in a hot and dusty environment. And the door switch could be worn out, since it is activated whenever the door is opened/closed, but you will have to check each of the involved switches with an ohmmeter. The high limit switches and the pressure switch are normally closed ( zero ohm ). If you don't have an ohmmeter you can also bypass the switches one by one, but this means more fiddling with wires.
A new door switch can be found for $12 here:
http://www.stove-parts-unlimited.com/Lennox-Micro-Switch-p/h3452.htm
Good luck and take care. Keep us posted.
