augur shoot gasket
chrisasst
1,289
cortland ny
maybe someone can help, I had to get a new augur shoot gasket. It goes behind the back heat panel ( 2nd one in 2 years) I am wondering if I am putting it on right. IT has 2 pieces. A thin square gasket piece and and the thick cotton like square piece. Should I be gluing these together and gluing the thin piece to the stove ( gluing = high heat gasket glue ) It looks like the original piece was stuck on there because there was reminents stuck to the stove.
Maybe if I did glue these they would not come off when I cleaned the the stove.
Any ideas..
Chris, we'd need to see either a pic of your stove, the gasket, and the area on the stove that it came from, or at least see what it looks like in the owners manual to really comment.
that would help..... here are some pics hopefully it makes sense
[Hearth.com] augur shoot gasket
Again, this is behind the back heat sheild....
the only thing I see in the manual is this about cleaning....."Inspect the auger chute gasket at this time. Make sure
the gasket is still in good condition and that it is in the original position
when the back heat shield is bolted back into position"
