Hello,
I hope you all can help, I have a Austroflamm Integra pellet stove, this is the second
season of using it. the blower motor has a mind of its own and fluctuates up and down, and
sometimes runs flawlessly. I was emailing someone about it I found on eBay. He says my
air sensor is bad, but told me to pull it out and look at it, if its covered in soot clean it and
check for a dark spot on the board. he also recommended resealing the glass and door. I
brushed off all the soot, and yes there is a dark spot on it. put back in and worked flawlessly
for about 3 weeks...started acting up again, yesterday I resealed the door, pulled the switch
again and this time sprayed it with a good circuit board cleaner. cleaned the entire stove,
blower motor,convection tubes, 8 holes behind the tubes,tube behind the convection tubes
Etc. put back together, started up......blower fan will not pick up right away goes up and
down, and now it has a tall lazy flame and smokes real bad....I noticed the door did not have
the rope gasket at the bottom of the center glass.....I put one there??...Is this still my air
sensor giving me grief??....it did not smoke before I changed the door and glass
seals...however I could tell from the pattern on glass after stove ran for a day that it was leaking before I changed the ropes.
Thanks for your help
Mtnman1
Mtnman1
