Welcome to the Forum;
That Baby is from the first year (1979) they were available with the flat top door, or new arched top style, "Cathedral" door. The flat top door was soon dropped and all models then had the arched top available only.
A barometric damper is installed in the horizontal opening and when cold, the flap will be closed, allowing the chimney to heat. When the chimney is heated and there is too much draft, the flap opens allowing indoor air to be pulled into the chimney and cools the rising exhaust, slowing the draft. So unlike a manual damper that is "closed" when the plate is across the pipe, a barometric damper is "closed" to slow the draft when the flapper is open. There is an adjustment on the damper for how strong you want the draft, and they are automatic for wind, atmospheric conditions as well as when the fire burns down. They keep the draft through the fire more constant and are required on coal stoves.
Below is the barometric accessory box installed on a Papa Bear;
