Currently have a disconnected EK Industries wood furnace (1985 vintage) in our 1880's brick farmhouse. Current heat is FA oil and house has one brick chimney that the furnace uses. I desperately would like to burn wood to heat but either need another chimney or change to a direct vent LP furnace..and switch existing chimney over to the wood furnace. Here is the question...with the wood furnace in the basement has anyone ever seen or heard of running a stainless chimney below grade through the foundation and away from the house some distance before turning vertical. We still have the original two hole outhouse and an 8' brick chimney along side the outhouse would look kinda cool. Underground pipe could have an approximate rise of 25% as the surrounding ground around the house slopes up. The other option is to build a new brick chimney which I'd rather not do but would if that were my only available option.  The house is full two stories plus full height attic. I'm scared of heights! Ideas?
Thanks,
Tom
			Thanks,
Tom
