Best way to utilize the Selkirk Vacuum Cleanout?
Don2222
9,273
Salem NH
Hello
Granted, this does not take the place of the normal stove cleaning.
Since we just installed the vacuum cleanouts, I was wondering what might the best way to use it?
1st I put some TFE paste on the one end of the nipple that I will never take apart.
Then I unscrewed the cap and put the shop vac on the nipple.
My shop vac hose is larger than the pipe. Is there a good way to make it an air tight fit?
After cleaning the ash out of the venting, I put the 150 PSI compressor hose in the air intake of the stove.
Got some more ash. How about putting the compressor in the ash chambers too?
  • [Hearth.com] Best way to utilize the Selkirk Vacuum Cleanout?
What is the OD of the nipple & the ID of the shop vac hose, Don? Seems to me you can get a small length of correctly sized tubing & run it from the ID of the vac line to the OD of the nipple, OR
sacrifice that particular shop vac hose & securely GLUE a PVC connector to the hose with the identical pipe thread & connect to the BIP with a properly sized union...
Pipe nipple diameter is 1-1/4 inches and shop vac hose is 1-1/2 inches. Thanks I will try something like that.
Perhaps use one of those black rubber fittings that are usage on drainage piping. I use one on the linteater shop vac adapter because my shop vac hose is smaller than the adapter connection.
Do you use an air compressor? In your case, to blow the ash out of the chamber where the exhaust fan is, into the shop vac connected to the vacuum cleanout?
No. I take the exhaust fan impeller off the shaft and use a paintbrush to loosen up the ash and then the shop vac to remove the loose ash.
For the exhaust path from the fan to the venting I use the 2" brush that came with the linteater set and the shop vac at the same time.
That's cool, so all the dust that the brush brushes out goes thru the vacuum cleanout into the shop vac! That is neat!
I just worked on a Harman Advanced today. I took out the fire brick and panels out and after wire brushing and cleaning them well, I coated both sides with Dry Moly. Looks nice and with the smoother surface, it should perform better too!
Hello
I also had a problem attaching the Vacuum Cleanout to the garage stove.
The vacuum cleanout needs a longer screw and it is very hard to drill a hole in it. So I put it in and used a drill bit instead of self tappers. I made 2 holes one on each side to support the heavier piece. Then screwed it in and it holds very well now and I can still easily remove it.
Hello
I also read that turning the exhaust blower on while the vacuum cleanout is still hooked up will catch any ash dislodeged while cleaning the stove!
