I'm trying to figure out what wood heating system and backup will work best for a new build and have gotten same great advise from you all already. The question has come up on what we would do if/when we go on vacation in the winter. In the scenario that I have a boiler in an out building, with tank storage in the basement, and we leave in the winter for say a week, how do we keep our pipes from freezing around our boiler in the outbuilding? Can you have the pump kick on every few hours to circulate the water to keep it from freezing? Drain it? Antifreeze in the pipes (though costly)?
Also, if you have a system as described, and it's to the point of only needing fire or two a day, do you ever have to worry about freezing pipes in the outbuilding? I know insulation will help but still are there any problems? Thanks
I have a eko 60 in a uninsulated pole barn I have a danfoss bypass set up incase I need to circulate water from storage in basement to boiler and back to keep from freezing. Like if my wife and I both have to go out of town for some odd reason. Monday I burned and charged the tanks to 180* before bed I went out and the fire was out in the boiler so I shut it off to keep the boiler from circulating my storage water back out to the cold boiler in the barn. Got up Tuesday checked the tanks and they were at 170* I told the wife you should be good to not make a fire. She came home from work and told me the tanks were at 158*. I said dont worry about a fire I will build one Wed. morning( I work 24hr shifts) I built a fire and turned on the pump and it made all kinds of noise
